I have a CP500 that won't come on. I purchased it over a while ago, and it did work then, but it's sat in a cupboard for over a year, and when I came to switch it on today, it gave me the message:
The two 675A cards in the left-ish positions (Matrix Decoder and Equaliser) have their fault LEDs lit up.
I swapped the 675A in the rightmost position (AC3-Decoder) - which does not have the fault LED on - with one of the ones that does, and the previously working card now has the fault LED on, and and the that previously had have the fault LED on doesn't. I tried this a few times with the same results, ie. cards in the two leftmost positions always have their fault LEDs on, and the one in the rightmost position does not.
I tried reseating all the cards in the machine, and blowing dust out, and once I'd done this I'm presented with a different error message (although the fault LEDs remain the same):
I have a box of spare cards (consisting of a 222sr/a, 662a, 661, 670, 671, 673a, 675, 681, 682, 685) that I got when I purchased it (all untested previously by me), and I tried swapping those cards out one by one, but I always get the same error message as before (CP500 Signal Path).
Anyone have any ideas, or things that I can try? The CP500 has version 1.65EX software installed. Note that I'm just an enthusiast, not in the industry or a repair tech, so I could be making a basic mistake, and may need things explained in basic terms (although I have an understanding of basic electronics).
The following fault cannot be cleared, so the system will remain in Bypass:
Cat No.675 Card / J12
CP500 Signal Path
CP500 Signal Path
