Hi all, I have to get two Philips FP3 (also known as type EL 8710 or maybe by US brand name Norelco) projectors working.
The exact type labels are:
projector I = Typ Nr. 8710 50
projector II = Typ Nr. 8710 66
The problem is, I couldn‘t detect any circulation of oil in the oil inspection glass. I‘ll check this further, as soon as I get there again but I want to address the issue just in case my first impression proves right.
The type label also specifies which oil should be used for the geneva drive:
projector I = use oil provided with projector
projector II =use Molykote M55 Typ EL 4805
I found that a Molykote M-55 Plus oil is available today but I think it‘s not completely identical with the EL 4805. Also I have an amount of oil type 3672 in stock for the Kinoton FP30 in my living room but I‘m not sure if it‘s suitable for the 8710.
What oil would you recommend for these machines?
