The more overdue maintenance you attempt, the more you find that needs fixing. Century JJ Non-Turret model.
Short Version:
1. How is the lower pad roller assembly stop pin affixed to the main chassis? We have one that has some play in the stop-pin itself. The pin can also rotate slightly. I confirmed it does not appear bent by rotating it 90deg, but unsure if that is pressed in pin or threaded in?
2. Other than a new assembly, is there a way you can think of to work around an impression in the lower pad roller assembly mounting shaft left by what appears to be a sharp or overtightened set screw? When re-inserting the assembly and tightening the set screw it always wants to shift clockwise (away from the sprocket) as it homes in on the previous divot left by the set screw.
Scene:
After having cleaned and oiled the pad roller shafts/rollers in the mag heads with success, I moved onto the other pad rollers yesterday. Uppers were no problem. One of my lowers is seized in place it seems, and the other has the problems above. It is apparent this issue has been building over time. An unknown predecessor or tech replaced the factory adjustment hex screw with a longer flat-head one and a lock nut to get the reach they needed to the out of spec stop-pin. But it's too long and also contacts the chassis when open, causing the assembly to be in a mid-point and likely to snap closed on you. It is also not a screw you can adjust with a tool without removing the assembly to make your adjustment.
I did find an appropriate replacement for the too-long adjustment screw, but the wobbly pin becomes the next (original) problem.
Additionally, after cleaning and oiling, upon re-insertion I was fighting with it to get an adjustment that would avoid sprocket skips due to the optical reader tension, especially at splices etc. Obviously this is a pad roller adjustment issue. It seemed my adjustments (even with the longer screw) had little impact. Eventually after several attempts, I realized that the set screw has created a "home" impression in the shaft, and so with the assembly at it's minimum distance, once you tighten the set-screw, it jumps up into a home position that has too much gap between the sprocket face and roller. It's quite possible I created that issue but I sure didn't feel like I was using that kind of force, this set screw also has a cupped bottom, the one in our turret JJ is longer and has a flat face bottom.
Currently, if I back off the set screw slightly the assembly will still function, it will allow it to lower enough that I can at least get film running, but it seems very non-ideal and quite touchy, introduces some play in the pad roller position, never mind that I can't actually set a pad roller distance properly.
Photos. I have a couple short videos attempting to show the stop-pin play and assembly play but will have to upload to youtube later.
IMG_5623.jpg IMG_5629.jpg IMG_5627.jpg IMG_5628.jpg IMG_5622.jpg IMG_5624.jpg
My initial thoughts towards a "fix", what are yours?
0. Tighten the stop pin? (assuming this is not press-fit or some other aspect is worn out).
1.Replace set screw with one less likely to cut into the shaft?
2. Possibly disassemble the arm and re-clock the defect 180deg away from the set screw? This seems pretty tricky to take apart and might involve knocking out a pin in the knurled knob?
3. Seek a replacement Lower Pad Roller Assembly or just the damaged part. Not sure about the stop-pin though.
4. Maybe grind/sand down the defect with emory cloth in hopes of removing the "homing" behavior as you tighten the set screw. (But ideally would be machined out on a lathe with the shaft removed from the assembly, as any flat spot would introduce the same behavior).
5. Make it worse, file a point onto the set screw so at least it can lock in a new position one more time (at risk of it always wanting to lock there forever).
6. Decide if trying to remove the other seized assembly is worth it for cleaning/oiling, it is functioning and adjustable as is.
Short Version:
Scene:
