HOWTO: Read Dolby SR-D audio from sound negatives
  • HOWTO: Read Dolby SR-D audio from sound negatives
    Hello.
    As promised, I'm sharing how to read the 5.1 audio from SR-D sound negatives.
    First, some words of warning:
    • Sound Negatives shouldn't be played in an intermittent transport (like a film projector). A continuous transport (like a studio dubber) that can also play both base-in-front or emulsion-in-front is mandatory.
    • Reading the SR-D 5.1 sound, be it from sound negative, married print, sound print, or from the MODisks themselves, even if someone ever finds out how to digitally decode the SR-D files in the MODisk to PCM (WAV), should be considered a last resort; since AFAIK nobody knows how to convert digitally (the code is locked inside the Zoran DSPs in the Dolby cards), this process involves a conversion from SR-D to analog and another analog to digital conversion.
    • SR-D 5.1 sound was lossy compressed with a relative of the AC3 codec, and not only has codec artefacts but it will suffer even more with further AAC conversions down a broadcast or delivery chain.
    • If there is multichannel analog or PCM sound of the final mix (be they AKAI DD8, ADAT, DTRS, Sony DASH, Mitsubishi ProDigi, WAV/AIFF/SD2 bounces), those are always a better source than the SR-D sound. Only use the SR-D sound if nothing better is available.
    We are using:
    • Sondor OMA-E film transport synched to video
    • Kinoton Basement Reader (with flywheel) jury-rigged to the OMA-E's film path (on the right-hand​ side, after the film starts descending to the destination reel - bolt it to the side of the cabinet frame, about level with the headblock)
    • Dolby DA20 (CP500 would work as well, but with the DA20 we don't have to worry about defeating the B-chain settings). CP-650 wasn't tested.
    • DOS-based PC with specific Dolby software (DRAS10.EXE, QC403.EXE) and serial connection to the DA20. We haven't tested if updated DOS versions, or the Windows equivalents, could work as well.
    • The computer can be anything from a 486DX to hardware equivalents of the latest rack computers supplied by Dolby with CA10 sound camera adapters (Pentium III, 440BX chipset). We're using an HP Vectra VE i8, Pentium III/633
    • Analog-to-Digital conversion, inputs in -10dBV=0VU sensitivity, trimmed with Cat.No.69T to -20dBFS
    I'll attach the information supplied by Mr. Thomas G. Kodros (engineer at Dolby) to Cineric. It's pretty clear and I can't explain it better. Basically, install the supplied software, and use the command-line switches as indicated. In the end, it was pretty easy - after we had the information, that is. That's why I'm sharing.
    Most SR-D positives are missing frames in the beginning and in the end, so the sound negative is a far better option.
    Good luck and let's keep film sound alive.
    Thanks for the tips to switch the DA-20/CP500 to "reading negatives" mode - I had no idea they had the ability to do that. And also for the QC software, I didn't have a copy of that so I will add that to my archive.
    It is also interesting to see the name "Mr. Thomas G. Kodros" - I had seen the acronym "TGK" in a few Dolby things before, but didn't know who it referred to.
    Originally posted by Tiago João Silva View Post
    this process involves a conversion from SR-D to analog and another analog to digital conversion [...]Dolby DA20 (CP500 would work as well, but with the DA20 we don't have to worry about defeating the B-chain settings). CP-650 wasn't tested.​
    Ideally you want a CP650 with the digital output card, because then you are not doing a digital -> analogue -> digital step. Or you can do what I have done, and modified by DA-20 to output digital audio, skipping the DAC. I currently have it outputting ADAT (throwback! Who remembers ADAT?) because that's the easiest for me to capture multichannel digital audio, but making it output AES3 pairs would be easy too, and would align with most current studio and cinema equipment. In fact, using a modified DA-20 is probably the best method, because then you're absolutely sure there is no additional processing going on in the CP500 or CP650 that you don't want.
    Yeah the printmaster on the MO disc is also currently unknown, and it's not currently clear to me what, if any additional processing is done by the CA-10 when it reads the MO disc and records the SR-D negative. It's not nothing, because the two formats don't seem to resemble each other, but it's probably not too much either (because why would you not have that additional step done pre-MO disc?).
    SR-D 5.1 sound was lossy compressed with a relative of the AC3 codec, and not only has codec artefacts [...] Only use the SR-D sound if nothing better is available.
    Indeed. I love your machine and it sounds like it works well, but it also does concern me that it's necessary already. Have original audio masters already gone missing? It's only been just over 30 years!
    Slightly off topic, but do you have/have access to a CA10? That's one part of the Dolby SR-D process that I'm still trying to find info on - I have the CA10 manual, but haven't seen one in person (or actually, seen any pics of one) yet. I'd also love to know what software runs on the PC connected to the CA10 to control it, and read from the MO disc.
      Hi, David! Nice work with your SR-D wiki, I had browsed it myself already when I was looking for some way of reading SR-D negatives!
      The original audio masters have a tendency to go missing when a country's film "industry" can't even be classified as a "manufacture". Portuguese films have always been living hand-to-mouth, and sometimes even eating their seed corn.
      For some films, the sound negatives were lost
      For many films, the magnetic final mix was lost, and only the optical SNeg remains - producers didn't care about the magnetic, the sound negative was the final product. Who cared if the magnetic remained in the lab that had struck the sound negative as collateral for unpaid bills? Safety copies? That's expensive... Or the producer folded, their warehouse was emptied and the magnetics were sent to the skip...
      Even when printmasters started being DATs, the issue of being left forgotten on the labs and no safety copies remained.
      So no wonder that very few producers ever considered spending the money on a backup of the 5.1 mix on a much more expensive format like ADAT or DTRS. The final product is the MODisk, they paid a pretty penny for the Dolby license already. And a clone of the MODisk? Why-ever for? The lab only needs one! And that's why for many films, the SR-D sound negative is our most original material for the 5.1 mix...
      We have a CA10 (which we're also using to take the 5.1 + Dolby Stereo mixes off MODisks when nothing better is available) and I hope we can help you. Below the Nuoptix AOS on the attached picture, that's a CA10 "crate" without the front panel attached.
      That one came to us without the original computer, which meant we had to get a computer, the Dolby ISA-bus interface card, and an Adaptec SCSI card to get it to work. Thankfully the MODisk drive was external and wasn't lost with the computer, one less thing to scour eBay for.
      I thought the CA10 DOS software was in the Warehouse, but I'm not finding it, so Dolby must've sent it to me. It's too big to attach to this post.
      Now, if anyone, ANYONE, has the MODisk that came with the CA10, that also didn't come with our CA10. On one side it had a backup copy of the CA10 software, and on the other side it was formatted as Dolby MODisk that could be loaded in the CA10 software and had a series of SR-D files that are necessary to set up and align the LED matrix that printed the SR-D blocks to the sound negative. We have blank MODisks to dump the raw files into, if someone has them, but Dolby UK was unable to find those files for us.
      I actually can't attach most things Dolby sent me, they're too big to attach. Even just the PDF of the CA10 Installation Manual would give you a very good perspective of what makes the CA10 tick (e.g, a list and description of all the cards in the crate)
      Two photos of the CA10 interface
      Last edited by Tiago João Silva; 09-23-2024, 08:09 AM. Reason: added CA10 UI screenshots
        David, I've sent you a package with technical information about the CA10 (installation/calibration/commissioning) and the Dolby software.
        How hard would it be to change our DA20 to digital output (ADAT would be fine) and maybe even our CA10 too? (although there AES would be better)
          Thanks so much for all the info you sent, it has lots of useful information that I wasn't aware of already. For example, I had no idea that on the Dolby Printmaster MO, the analogue audio (the .SVA files) are encoded as Dolby AC2. I'll have to see if that helps me read anything useful from them.
          It is also great to see some pictures of a CA10 - I've mentioned this to you, but to put it here as well, it is interesting to note that the CA10 and DA10 share quite a few cards.
          For converting the DA20 to digital output, it is not a tricky technical thing to do, but you'd want a proper solution, rather than what I have which is some wires soldered onto my DA20 that then go to a prototype board with the ADAT circuitry (I'm sure I had a picture, but I can't find it right now). The best solution would be a drop-in replacement card for the 686 DAC to make it output AES3 (or some other digital output) - and a few people have now told me they'd be interested in such a thing, so maybe I should look into it. It shouldn't be hard, just need to find a suitable AES3 transmitter chip (I had a quick look and couldn't find a 6 channel one, but I can probably get away with 3 stereo ones). If I ever do that, I'll let you know.
            Hi Tiago, great to connect online! I’m also working with CA10 and Sondor Resonance.
            I was curious about scanning Dolby SRD sound negatives on the Sondor, I scanned only print film for Dolby SRD, but it seems like you've already mastered it—amazing work!
            Could I ask you about Dolby SR? How are you scanning Dolby SR in Portugal with the Sondor?​
              Obligatory: do you have the Dolby CA10 Alignment and Test Disk, by any chance? Do you have any way of copying the files inside?
              As for reading SR-D sound negatives, don't thank me, thank the Dolby engineers that had the forethought of putting the code in to read sound negatives, which I was pretty sure they had done; why would they force themselves during the development of the system to take a print out of every test sound negative just for reading, when it was little more effort than flipping the bit values in the code? The extra code must have paid for itself in the first week! And then they shipped that debug code in production, and didn't forget about it later.
              The Kinoton sound head would be able to read the SVA track as well, but not from negative. We read SVA tracks (positive and negative) just like you must be doing it too, with a Resonances (on a Sondor Versa) - but it needs a separate pass after the Dolby Digital track and sync both by the two-pop (greatly helped by Dolby mandating the pop at ACTUALLY two seconds from FFOA, because otherwise I just KNOW everybody would have continued to put the pop wherever).
              The Czech Film Archive is getting a Scanity and it seems like they will be reading the optical sound from the full-frame scans - how exactly, I don't know, their visit here in Lisbon was a whirlwind and I couldn't get many details. I could have misunderstood and it could be just a regular reader or even Resonances too, since Scanity scans film in real-time.
              Sondor/Université La Rochelle never finished that part of the Resonances software (scanning to images, and then converting from images to sound). By having an intermediate step of image files, you could even do manual repair/dustbust of the sound track image before converting to sound; Resonances remained a "stream" processor - it converts a stream of image sensor values to a stream of digital samples.
                maybe they are using AEO light or something derived from that tool? https://usc-imi.github.io/aeo-light/#hero
                  would'nt a sound negative still read with an optical reader? Maybe a little noisy but I would think it would track? You may have to flip the phase or invert the track in your DAW.
                    With regard to reading SRD negatives: wouldn't it be easier to flip the polarity on the camera side? I don't know enough about CCD cameras to know how to do this, but it should not be hard to switch it from producing a negative image to a positive one.
                      An analog sound negative can be read with a regular reader, with a lot more noise, because most of the noise comes from the transparent ("white") part of the track and even stuff like "noise reduction" bias on the optical track is trying to minimize the white area of the track on the positive when there's silence, which means maximum white area on the negative when there's silence; but most importantly, it will have more image-spread distortion.
                      This distortion is a by-product of the photographic process, but thankfully, it goes in the opposite direction from negatives to positives. This means that to get zero distortion in a positive, you have to introduce on purpose protographic distortion on the negative, in a specific amount for each lab/stock/printing light combination. Badly-compensated image-spread distortion can be heard as "spitting" on 'ss' and 'sch' sounds.
                      A regular reader can't compensate for that effect.
                      Many special readers have promised to compensate for this effect and avoid IS distortion; my only experiences have been with LaserInterface and Resonances, and I could never get good results from LaserInterface.
                      With Resonances, we can change the exposure and simulate changes in printing density and the sensitometric curve when reading negatives (up to a point) so we can get closer to minimal IS. Since we no longer have the cross-modulation tests for most of the sound negatives, we can go a lot faster by ear with Resonances than by printing a series of exposures to actual positive.
                      The other thing with Resonances is that it's mostly immune to film grain and less-than-perfect opacity of the black sections, so the background noise is a lot lower even when reading positives.
                      More information about Image Spread and Cross Modulation can be found in the Kodak H-44 document I'm attaching, "Cross Modulation Testing for the Motion Picture Laboratory"
                        It's a matter of trying. Although I think that would also flip the perforation signal which I fear is being used for sync/clocking by the system.
                          [QUOTE=Tiago João Silva;n42504]Obligatory: do you have the Dolby CA10 Alignment and Test Disk, by any chance? Do you have any way of copying the files inside?
                          1. Unfortunately, I haven’t found a way to read MO disks through the CA10. We’ve been collecting MO disks from a closed recording studio (with no original files) and are scanning these sources in real-time for preservation.
                          2. As for the Scanity, I understand it can scan both image and audio if an audio head is added as an option. We also looked into a quote for this setup, but the cost of even a single audio head was extremely high.​
                            [QUOTE=Min young Park;n42670]
                            What do you want to access in the MODisks? The encoded sound, or the files themselves?
                            For the files, you'll need an MODisk drive like the Sony SMO-F561 (internal) or RMO-S561 (external) SCSI drive, and a computer with a SCSI controller card (and the correct SCSI cables). The Dolby MODisks are formatted in FAT16 and the files can just be copy-pasted.
                            For the sound, it's more involved, unless David upthread has a breakthrough and finds out how to decode the files with software. You need the whole CA10 system working to get at the sound of the MODisks.
                            Also, since you say you've been collecting MODisks from a closed recording studio, are you sure those are Dolby MODisks? Studios usually only had the Commercials/Trailers MODisks, feature film MODisks should be in the leftovers of a film lab or in a producer's archive. That's because there were very popular digital multitrack studio formats that used MODisks, like the AKAI DD-8, which are not compatible or even technically similar to a Dolby MODisk, just like if you put a computer CD-ROM on a CD-Audio player you don't get sound, even if the data format in the disk is the same.
                            To read 5.1 Dolby Digital and LtRt Dolby Stereo out of a Dolby MODisk you need:
                            • A working CA10 "crate" (rackmounted enclosure)
                            • An MS-DOS-based computer with the Dolby ISA bus interface card and an Adaptec SCSI controller
                            • The Dolby software and the Adaptec drivers installed and configured
                            • An MODisk drive like previously mentioned
                            • A biphase source (48 Hz or 240 Hz), preferably resolved to the master digital clock
                            • A bespoke cable for the CA10 crate from its very special plug to 8 analog audio balanced line-outs and one line-in for the external biphase signal, the pinout is on the Operation Manual. If you have the original Dolby harness, it should have those prewired - 6 channels of "monitor" for the 5.1 sound, 2 channels connected to the input of the optical recorder for the SR-encoded LtRt, and one External biphase input.
                            If you are lucky enough to have a complete Dolby Computer/CA10+Westrex/Nuoptix system that "ran when parked", probably all you need to drive the CA10 and read some MODisks is an external biphase source.
                            For that, we use a Sondor OMA-E (the same one pictured above in one of my posts) with a film loop, resolved to Video Reference (Rosendahl NanosyncsHD), outputting 48 Hz biphase from the DIN plug on the back into the CA10. Select Sync Source External in the Dolby software, hit Play on the Sondor and the CA10 follows in sync with the Sondor.
                              Besides the SA10 one can read and playback the content of Dolby encoded MO Disks via the DMU which was a later model provided by Dolby to Mixing Studios and Optical Transfer facilities. The DMU was a stand alone unit with AES/EBU inputs and outputs. It would also sync to external time-code and video signals besides biphase. I was able to restore a couple of feature film soundtracks from the MO disks as the production company had lost the original DA-88 multi-track masters. It is a great piece of engineering even by today's standards. Should you require a copy of the user manual, please feel free to send me a private message.​
