I thought I'd ask the hive mind too, Brad is aware (and our spindle design was a complete surprise to him). But the Film-Tech plastic 24" 35mm reels struggle with our reel arms and spindle locks. Just a mm or two too wide.
I'm headed in today to try to see if the format adapter shaft can be shifted at all in it's housing, but it doesn't look promising.
I "believe" our arms are Simplex/Ballantyne style 35/70mm, but perhaps someone else can ID them better based on the photo of the 35mm spindle.
http://www.film-tech.com/warehouse/manuals/SMXARM.pdf
http://www.film-tech.com/warehouse/manuals/BALARMS.pdf
If adjustments are not possible. What would ya'll try/do? Unfortunately we only have enough 6K house reels to serve as handling reels, not enough for a full run. And the whole goal was to use the friendlier 8" cores on the FT reels anyway. Our in-house tech day is Monday, festival tech and screening is the 26th.
I've ordered a last ditch option, 4 5/16th "drill depth stop clamps" to place over the flipper instead of flipping it.
https://www.amazon.com/dp/B0CF9QDM66
Brad did offer to loan us enough goldberg 24" reels to make it happen, but would arrive mid-week. Should we pull the trigger on that just in case?
With our 70mm spindles on we often tape the flipper to the reel, because the flipper's detent is often not strong enough to keep a reel from walking off on it's own. But it would feel very iffy to tape this one that is not even closed 45deg, with such a heavy reel in play.
