Putting an IMS3000 in a Christie CineLife S4 projector I ran into some odd problems.
First, there aren't "channel numbers" in "CineLife" projectors with their new PIB (or whatever they call it now), macro name cus are used. But an IMS macro cue with the exact channel name does nothing. After a lot of asking around I found you need to put the macro name in as "PRESET macro-name". I searched the installation manual for PRESET and no hits. They actually can do channel number cues but only when you have a macro with the name "1" or whatever number you like. It seems silly to have macros with nondescriptive names just so the legacy channel switch method works. I did not try that way.
Second, the cue library included in the IMS3000 for a CP750 has cues as "cp750.sys.fader.50 \n" - note the space before the "". That apparently worked with previous software versions but no more. The space has to be edited out of the cue. Dolby will presumably fix this is the next IMS3000 version release. Embarrassing to have a Dolby server error trying to control a Dolby CP. I have not tried with a 950 or 850.
I don't know if a software update disables existing CP750 cues but that's unlikely IMO.
Just FYI. Maybe save somebody some grief.
