Help with dac pinout
  • Help with dac pinout
    Hi does anybody know the analog out pinout of the proyecson p-dac11?
    since it appears to be a standard plug n play type unit that is designed to feed an analog processor like dolby or usl, i would assume the db 25 output wiring would be similar to other dac units like de-remi or usl...contact the manufacturer for wiring diagrams pin-outs should be the same assignments.
      Wouldn't it be better to continue on the previous thread you started?
      http://www.film-tech.com/vbb/forum/m...yecson-p-dac11
        The brochure mentions an 8ch balanced analog audio output. I would assume it follows the Dolby DB-25 balanced pinout scheme, since Proyecson also made accessories for Dolby processors. That would be the same pinout as e.g. the DMA8PLUS.
        https://www.filmtechniek.nl/wp-conte..._Manual_v3.pdf
          Could be the pinout is part of the issue. This DBX unit is unknown to me but there's a migration to Tascam pinout. Including the CP950.
            I would email Proyecson about the pinout. The manuals section of their website is currently not available, but they will probably be able to send a PDF by email.
