As of yesterday, I noticed what looks to be visible heat dissipation onscreen. Attaching a video clip here (If possible, try to watch in 4K). Think of a drop of ink into water and how it moves. This SP4K has been in service for a year now, and is only used a few times a month. I'd expect this coming from xenon but I am a little surprised seeing it come from a laser light source. Is this a common occurrence regardless? Thank you in advance!
Barco SP4K - Visible Heat Dissipation?
That usually comes from the heating in the auditorium (warmer/cooler air moving across the light beam). Particularly if your air inlet are on the ceiling and particularly when you turn it on in a cold room - the hot air will float on the top giving a "mirage" effect.
Could that be your case as well?
