IMS3000 Issue deleting content
  • IMS3000 Issue deleting content
    Hi all,
    Every now and then I have this issue: I select a single cpl and when I go to delete is says I have selected 2... then it will not allow me to delete. The only way I can delete content is doing it from the TMS. This only happens sporadically and I haven't noticed any sort of pattern. It seems to be happening more regularly and I fear it is a symptom of a larger issue. I've attached pictures. Any ideas? Thank you!
    We have this and narrowed it down to an odd bug whereby if you filter the content at all (it looks like you might have filtered to just features), then it simply won't delete, you get the 'not found' error.
    If you just scroll down the list to select and delete, or use the text search then it works fine.
      Well look at that! So odd, I can't complain about an easy fix though, thanks very much!
        I've found that it does this if you use Microsoft Edge with the IMS3000's web UI, but not Firefox.
          Dolby recommends Chrome for all webGUI products. I usually use Opera (Chrome engine) but will use Chrome for some critical stuff with Dolby UIs.
            It happens when you sort CPLs by any column. do not use sort, just type in search bar. BTW search bar also can be used to sort, but doesn't have the bug, just type "feature" and it will bring all the features.
