New model of liquid cooling pump for Barco DPxK B and DP2K C series
  • New model of liquid cooling pump for Barco DPxK B and DP2K C series
    Just thought I'd mention this in case it's useful to everyone.
    I replaced a pump on a DP4K-32B this morning. Barco is now supplying a new model of pump for the B and C series projectors: this is Barco part # R9801816, and Iwaki model # NRD-08TV24-01. This appears to replace Barco part B401303K, Iwaki model # RD-05HTV24-15. The box came with a sheet warning that the projector's firmware had to be updated to the current version before swapping out the pump, or else damage to the new pump could result.
    The release notes for firmware version 2.10.101 (released in June, and appears to be the current version) say that it adds support for the new model of pump, so this is presumably the version you need to upgrade to before replacing the pump. I did so, and everything was good afterwards: the projector ran for 10 minutes happily in refill mode, and then for another 10 with the bulb on. Fluid agitation in the reservoir looked normal.
    Per the data plates on the pumps, the old model requires 1.5 amps of power and the new one 1.6. Presumably the new software lets the fan control board give it that extra .1 amp, whereas older versions do not.
    The new pump also came with a hardware kit consisting of two brackets, fasteners, shock absorbing standoffs, and an adapter cable. The new pump has a slightly bigger diameter than the old, but it fitted onto the heat exchanger sub-chassis without the need for any of this hardware. So I'm guessing that the kit is needed to install the pump on a C series projector, but not a B series.
    But the crucial gotcha is to update the firmware before you start.
    Thanks for the heads up. I was unaware of the new firmware too.
    According to the release notes. The pump was done for 2.8.86. I was aware that there was a new pump and adapter plates:
    Changes / Bugfixes in 2.8.86
    • Add lamp R9801827 ("USHIO (R) DXL-40BAF/LU")
    • Improve LCB communication
    • Bug fix for LCM pump error
    • Improve I2C communication on Cinema Controllers R7681222
    This is what is in the new firmware:
    Changes / Bugfixes in 2.10.101
    • Bugfix: RGB block temperatures where sometimes not visible
    • Support for "DP4K-CGS X50"
    • Add lamp R9801862 ("Osram(R) XBO 7000W")
    • Add lamp R9801863 ("Ushio(R) DXL-30BAF/LU")
    • Add lamp R9801990 ("Osram(R) XBO 4000W/DHP L")
    • Add lamp R9801935 ("PLUSRITE(R) PDXL-2001-B")
    • Add lamp R9801936 ("PLUSRITE(R) PDXL-4500-B")
    • Add lamp R9801844 ("PLUSRITE PDXL-2000-B")
    • Add lamp R9801845 ("PLUSRITE PDXL-2200-B")
    • Add lamp R9801846 ("PLUSRITE PDXL-3000-B")
    • Add lamp R9801847 ("PLUSRITE PDXL-3001-B")
    • Add lamp R9801848 ("PLUSRITE PDXL-4000-B")
    • Add lamp R9801849 ("PLUSRITE PDXL-4001-B")
    • Add lamp R9801860 ("PLUSRITE PDXL-6000-B")
    • Add lamp R9801291 ("PLUSRITE PDXL-6500-B")
    • Add lamp R9801872 ("LTI(R) XDC-1600B")
    • Add lamp R9801873 ("LTI(R) XDC-2500B")
    • Change max runtime of lamp R9801138("LTI(R) XDC-2000BL") to 3200 hours
    • Change max runtime of lamp R9801779("OSRAM(R) XBO 6500W/DHP XL OFR") to 900 hours
    • Improve DVI EDID
    • Improve LCB firmware
    Nothing about the pump.
    [EDIT] From the service manual:
    In order to have this pump behave correctly, make sure you have upgraded the projector software to version 2.8.83 or newer. So 2.8.86 was sufficient for the pump. It is likely to adjust the parameters of the software reporting an issue.
    Here it is:
    Release notes
    Changes / Bugfixes in 2.8.83
    • Onsite marriage with remote pin code entry
    • Improve I2C stability on 2nd generation cinema controller R7681222
    • Add lens R9801333 ("MINOLTA(R) 1.2" DC2K 1.49-2.03 DC4K 1.35-1.84")
    • Add lens R9801334 ("MINOLTA(R) 1.2" DC2K 1.60-2.32 DC4K 1.45-2.10")
    • Add lens R9801353 ("MINOLTA(R) 1.2" DC2K 1.82-2.98 DC4K 1.65-2.70")
    • Add lens R9801354 ("MINOLTA(R) 1.2" DC2K 2.19-3.76 DC4K 1.98-3.40")
    • Add lens R9856525 ("INVISION(R) 1.38" DC2K 1.25-1.90 DC4K 1.13-1.72 I")
    • Add lens R98565252 ("INVISION(R) 1.38" DC4K HC 1.13-1.72 I")
    • Add lens R98565253 ("INVISION(R) 1.38" DC4K VHC 1.13-1.72 I")
    • Add lens R9856526 ("INVISION(R) 1.38" DC2K 1.49-2.06 DC4K 1.35-1.86 I")
    • Add lens R98565262 ("INVISION(R) 1.38" DC4K HC 1.35-1.86 I")
    • Add lens R98565263 ("INVISION(R) 1.38" DC4K VHC 1.35-1.86 I")
    • Add lens R9856527 ("INVISION(R) 1.38" DC2K 1.61-2.31 DC4K 1.46-2.10 I")
    • Add lens R98565272 ("INVISION(R) 1.38" DC4K HC 1.46-2.10 I")
    • Add lens R98565273 ("INVISION(R) 1.38" DC4K VHC 1.46-2.10 I")
    • Add lens R9856528 ("INVISION(R) 1.38" DC2K 1.82-2.86 DC4K 1.65-2.60 I")
    • Add lens R98565282 ("INVISION(R) 1.38" DC4K HC 1.65-2.60 I")
    • Add lens R98565283 ("INVISION(R) 1.38" DC4K VHC 1.65-2.60 I")
    • Add lens R9856529 ("INVISION(R) 1.38" DC2K 2.21-3.70 DC4K 2.00-3.35 I")
    • Add lens R98565292 ("INVISION(R) 1.38" DC4K HC 2.00-3.35 I")
    • Add lens R98565293 ("INVISION(R) 1.38" DC4K VHC 2.00-3.35 I")
    • Add lens R9855947 to DP4K-13BLPHC and DP4K-18BLPHC
    • Support for new IWAKI pump (R9801816)
    • Add button module 2nd generation firmware 1.1.2 to package
    • Add lamp R9801779 ("OSRAM(R) XBO 6500W/DHP XL OFR")
    • Enable DVI signal path test on the 2nd generation cinema controller (R7681222)
    • Improved support for GDC server for 2nd generation cinema-controller (R7681222)
      Sorry; had multiple PDFs open at once and misread.
