Cinema DTS on MediaInfo!
  • Cinema DTS on MediaInfo!
    I’m happy to inform you that finally Cinema DTS files are recognized by MediaInfo!
    Me and Jérôme Martinez (lead developer of MediaInfo, https://MediaArea.net/MediaInfo) worked hard together to discover the info hidden inside the .aud and .aue files (and not only there) to let MediaInfo show them all!
    MediaInfo is now able to show 100% of theatrical
    • DTS 35mm Stereo
    • DTS 35mm 5.1
    • DTS 35mm ES 6.1
    • DTS 70mm 6-track
    • DTS 70mm Special Venue 8-track
    • DTS 70mm 5.1: it should find out almost all of them, but few may be confused with DTS 35mm 5.1; in case you spot a title not recognized as 70mm, please drop me a PM.
    Many thanks to:
    Jérôme Martinez – he’s the genius behind everything!
    the whole MediaInfo team
    the great members of this and other forums who helped me with DTS info
    Have fun!
    These are examples info showed up on MediaInfo:
    Code:
    General
    Complete name :             filename.AUE
    Format :                    APT-X100
    Commercial name :           DTS 35 mm
    File size :                 103 MiB
    Duration :                  16 min 19 s
    Overall bit rate mode :     Constant
    Overall bit rate :          882 kb/s
    Movie name :                movie title (w/filt)
    Part/Position :             1
    Reel/Position :             1
    Production studio :         ABC
    Catalog number :            12345
    Audio
    Format :                    APT-X100
    Bit rate mode :             Constant
    Bit rate :                  882 kb/s
    Channel(s) :                6 channels
    Channel layout :            L Ls C Rs R LFE
    Sampling rate :             44.1 kHz
    Compression mode :          Lossy
    Time code of first frame :  00:00:06.00
    Time code of last frame :   00:16:25.06
    Stream size :               103 MiB (100%)
    Language :                  English
    General
    Format :                    APT-X100
    Commercial name :           DTS-ES 35 mm
    File size :                 113 MiB
    Duration :                  17 min 55 s
    Overall bit rate :          883 kb/s
    Part/Position :             1
    Reel/Position :             1
    Production studio :         DEF
    Catalog number :            65432
    Audio
    Format :                    APT-X100
    Format settings :           ES Matrix
    Bit rate :                  882 kb/s
    Channel(s) :                7 channels
    Channel layout :            L Ls C Rs R LFE Cb
    Time code of last frame :   00:18:01.26
    Stream size :               113 MiB (100%)
    Language :                  English
    General
    Format :                    APT-X100
    Commercial name :           DTS 70 mm Special Venue
    File size :                 106 MiB
    Duration :                  10 min 38 s
    Overall bit rate :          1 399 kb/s
    Part/Position :             1
    Reel/Position :             1
    Production studio :         XYZ
    Catalog number :            23456
    Audio
    Format :                    APT-X100
    Bit rate :                  1 411 kb/s
    Channel(s) :                8 channels
    Channel layout :            L Ls C Rs R LFE Lc Rc
    Time code of last frame :   00:10:43.99
    Stream size :               106 MiB (100%)
    Language :                  English​
    Great work!
    Having used the MediaInfo in our own tooling, it's great to see this addition. I don't know if it will ever really come in handy, but it's nice to see the devotion to support even the more obscure media formats out there.
      Just for interest's sake. What makes these types of files? How/where are they used? Were am I likely to see them as a cinema tech or in general?
        This is awesome! Great work, will be very useful. I had no idea the files contained so much info.
          Actually files contain most of the info, but not all; for example, the info about the DTS type (35mm, 70mm, ES) is extrapolated from the serial number.
            I would suggest you consult the Wikipedia article on DTS, especially the paragraph titled "Theatrical Use",
            since theatrical DTS is a whole different can-of-soup than the consumer version of DTS sound.
            As to how likely you are to see/use them-
            > Are you running film? Especially 70mm?
            On my job we run a mix of old and new 35 and 70mm titles. Most of the time, the 35mm disks are often
            either missing or are scratched/broken when we get them on some of the older films. (The exception is
            that disks for films from the Warner Brothers Archives are usually in very good condition), However, we
            always go with the DolbyDigital™ sound tracks on 35mm. For 70mm, 99.9% of the time, DTS sound is
            the only available option. The sound content arrives either on disks, or, more commonly now, on a thumb
            drive shipped with the film. For older 70mm titles, that were issued without DTS, at my venue we still
            have the ability to play back from 35mm magnetic sound tracks, which is pretty much an obsolete format.
            Just For Fun, Here's A Picture Of One Of The 70mm
            Projectors I Work With. I've Also Occasionally
            Run A Pair Of 70mm Kinotons At Another Venue
              Very nice!
              You should also add in the DTS subtitle files, and the narration format. I have documented how the subtitle files work and written a simple decoder at https://github.com/davidferguson/35m.../sbt-format.md - but feel free to ask me for help or example files.
              The narration format, I'm not sure on. Perhaps with the work you've done with the audio files you'll be more familiar with how they work? I think they're just a single channel of apt-x100 encoded audio, but I'm not 100% sure on this.
                Thanks David!
                May you provide some subtitles and narration files? Can't promise I would undestand everything, though!
