I have a bunch of new Rectangular (Hot Mirror) heat filters for an ORC lamp house. How can you tell which side goes toward the lamp? They have a tiny white sticker on one side so I assumed that side went toward the lamp. When I looked at the 2 that are in the lamp house now, the sticker is on the projector side.
Hot mirror (Heat Filter)
The "emulsion" side goes towards the lamp. Sometimes this is marked, often by a small etched mark.
But here's a trick I always use whenever I've taken a heat filter out and forgotten which side is which:
1) Lay the filter on a table. ( use a sheet of paper or a clean rag to prevent scratching)
2) Find something with a 'point' on it, like a sharp pencil, a toothpick, or a pin.
( I usually use one end of an un-bent paper clip)
3) Shine a bright light from a flashlight or your phone obliquely across the surface that's facing up.
4) GENTLY touch your 'point thing' to the surface of the filter, obviously being careful not to scratch it.
> If see a gap between your "pointer" and its' reflection, than that's the the 'glass' side of the filter.
> If your 'point' and its' reflection appear to touch each other, than that's the "filter' side
which should face towards the light source.
I learned this trick along time ago from an old theatrical lighting technician, and it works every time!
( and it's a fun thing to do if things get dull at your next projectionists party!)
- Likes 3
