This might be related in some way to the topic Ryan started with his JJ. Looking for advice
In our changeover booth, one of our projectors produces a slight ghosting at the top and bottom of the image. Turning the shutter knob in one direction can reduce the symptoms on one side, but worsen ghosting on the opposite side of the frame. I've also noticed this projector occasionally produce a bit of a knock sound like the one describe by Ryan in the other thread. Only with film running, and always with dirtier or older film. I checked the vert. shaft and there was a bit of movement up and down that I was able to remove by threading down the collar at the top of the shaft. Still the ghosting top & bottom persists.
The ghosting also seems to pulse consistently somewhere between 2 to 3 'pulses' per second. With each pulse the white streaks from the ghosting are accentuated
It sounds like it could be a worn out part. Where is the best place to start with troubleshooting, or part replacements?
We have a few parts projectors here that I can try swapping components and parts with
