At a theater where I regularly fill in as a projectionist, I have started to find heavy emulsion build-up on the tension bands on one of the two projectors. I usually have to deep clean the projectors if its been a while since my last visit, and they run a lot of "grindhouse" prints, so the first couple times I just assumed it was a result of the prints they were running and a lack of cleaning. However, I think this is the third time I have now come in to find heavily caked emulsion in the same locations on the bands (worse on the outboard band, heaviest near the lateral guide disc on the outboard band, and towards the bottom of the inboard band), and only on Projector 2. It's bad enough that it's difficult to scrape off. They must have run a black and white film most recently, because it's usually purple, and thus clearly shed emulsion. To the naked eye there doesn't seem to be anything wrong with the gate (curved runners look nice and smooth), so I'm confused as to what may be the source of the problem.
It's probably unrelated, but last year I replaced the tension bands on Projector 1 because they had done something (I can't even imagine what) that punctured a hole in and cut a nick in the outboard the tension band. I tried to figure out how on earth that happened and couldn't come up with a plausible scenario. I'm wondering if whatever was done to cause that damage may have also been done to a lesser degree on the other projector. At that time we sourced two pairs of tension bands but I only replaced the obviously damaged ones in order to get all the life we could out of the "good" set in the other projector. I could replace these as well, but I have no idea whether the likely source of the issue is just wear on the tension bands, or if it may be caused by something else (ex., a gate issue) in which case the new bands might also be damaged if the underlying problem isn't resolved. I don't want to waste NOS tension bands if they'll also get damaged.
Or maybe I'm just overthinking it, and if they cleaned the damn projector after every reel there wouldn't be any buildup. My primary concern is that this is resulting in film damage.
