Hi All! Quite awhile since I posted, but need help on this... I inherited a Simplex PR 1014 around 2014 and have been very happy running and it has been behaving fine. What I never got around to setting up for it was the framing and door lamp. I tested the circuit with a 9V battery and all lights lit (dimly though). Id like to have something more permanent and brighter than that 9V and went to the transformer, which I still had, which has the following on it: "P-3144 Freed Xmfr. P/N 24650". I tested both sides and one of the side has an open circuit, so I am presuming it's bad. I have tried internet searches and come up empty handed as to type, ratings, new compatible version, etc. I had also purchased a 12V 2A DC power supply, with screw down terminals, that did NOT light them up. When I put the meter on it, it looked like the voltage drops from 12v, w/ no circuit to less than 1V connected to the bulbs. No light at all from them. Any ideas what I can do to power this? Many thanks in advance for responses.
Simplex 35- PR 1014 Threading Lamp Power Supply Question
First off, you want a 6.3V filament transformer. The standard lamps were #55 and wired all in parallel. The maximum number of lamps was 4 (framing, via door switch, door lamps (2), via its own switch, and upper magazine). I see in one place that an Eiko #55 draws .41A...with a 4 lamp maximum that is 1.64A at 6.3VAC, you get 10.33W. You need a 120 to 6.3 filament transformer with, at least a 10.3W capability. My notes show that Strong was supplying a 5V version (probably so the lamps would last longer since they didn't need to be so bright and allow for higher primary voltages than 117VAC) and with a 3A capability. Stancor model P-6467. The 6.3V version was the P-6466 (those are the Stancor models, not Simplex "P" numbers). You'll find that the 6.3V is going to be easier/cheaper to find than the 5.0V one. Naturally, if you are not going to have the upper magazine, you can drop the requirements a little.
Also, do yourself a favor and put a fuse on it so when a wire gets pinched, or touched around the spot sight box cover where the door switch is, you pop the fuse, not the transformer. Something in the ⅛ - 1/4A on the primary should do it.
- Likes 1
Steve, yes you live up to your title of Film God....Not even 3 hours after posting, you have the answer (and then some!) MANY THANKS! I see some 6467's out there and am mulling options. I like the idea of a touch dimmer to save bulbs, vs having to change more often. I double checked and yes I have the 55's. Just one minor question on the transformer, as all I see are pics of them and no info sheets....Which side uses the 2 black wires and which use the blue & yellow? Also great idea about the fuse! I'll try to get to my local Radio Shack and get one of those pieces (YES there is still a Radio Shack in New Holland, PA!)
- Likes 1
The black wires will be the primary side. Also, you'll find that they have a center-tap on the secondary side (the one with the yellow stripe going through it). I seem to recall that the secondary had red wires but regardless...the one with 3-wires will be the secondary. Plus, the paper wrapping of the transformer windings normally is labeled too.
- Likes 1
Originally posted by Bill Duelly View PostOk. Cleared up and confused. Secondary tap? What is that for as I only will need 2 wires…. I’ve seen pix of this transformer with both 3 and 2 outputs. I purchased one with what appears to be 2 wires, yellow and blue…..
A lot of equipment uses transformers with multiple taps, each providing a specific voltage as referenced to the common (The starting end of the winding) lead.
So, in your case, with the 6.3 v lamps, you'll use the yellow leads and cap off the blue center tap. Also, since that is a 5v transformer, your lamps will be a bit dimmer than normal. You would have needed the P-6466 to get the full 6.3 volts.Last edited by Tony Bandiera Jr; 01-21-2025, 01:37 PM.
- Likes 1
Tony...perhaps...the primary is 117V. Depending on his wall voltage it could be a bit higher. It is a 3A transformer on the secondary...were he is only loading it to just under 1.5A...so, I suspect it will be somewhere between 5 and 6V. That is what was being shipped by Strong for Simplexes. Technically, the #55 lamp is 7V, I believe. There is a range of suitable lamps too. is/was quite popular (it is 6.3 lamp, known for long life and popular in pinball machines). There are LED options in the too. is a brighter lamp.
I suspect that he'll be happy with most any combination.
- Likes 1
Post Mortum: Finally got to the Radio Shack for fuse holder and miniature fuses. 1/4 amp. I had a very deep oversized junction box, with cover that I built all that into and affixed to the side of the projector base. Regarding bulbs, the 55 seemed to be a touch too dim, but the key word pinball prompted me to try the Eiko brand 47 bulb that I had extras of after recently re-bulbing my pinball machine. Well just enough little extra brightness to be just fine. THANK YOU AGAIN STEVE AND TONY!
- Likes 2
