Just had to deal with the same fault in two separate places, two days apart, and wondered if anyone had any thoughts.
On June 3, a customer requested a service call because he could not connect via LAN to his projector (a DP2K-6E). When I got there (on June 10), I connected to the projector’s CCB directly (straight shot patch cable - laptop to CCB) and Wiresharked the connection – absolutely nothing; no packets coming out of the CCB at all. Otherwise, the projector appeared normal. The tail light was green, and it could be controlled by an IP connection into the ICMP, using Web Commander.
I pulled the CCB out of the card cage, cleaned the contacts with DeOxit, and reseated it. Once it was back in and the projector rebooted, I did see packets on Wireshark. The CCB had reverted to the factory default IP address (192.168.100.2). All the CCB settings appeared to have reverted to their defaults, too. I reflashed all the software and firmware, restored a clone package taken earlier, reset the IP settings to what they were before the fault, and the projector worked without fault or issue. All the diagnostic self tests passed.
Earlier this evening, I was called to the exact same fault, and successfully fixed it using the exact same actions, on a DP2K-20C (with a Dolby cat745 IMB, not an Alchemy) at a totally separate site.
Has anybody else encountered this? My fear is that this is an early warning of a CCB about to bite the dust.
