We were alerted to a potential visual glitch during a screening of RAGING BULL - it was described to us as 'a frame of colored squares' during a particular scene. When we went to try to replicate the issue, we were immediately able to. However, when we tried to replicate it a second time, we couldn't; nor the third or fourth. Eventually we saw it again, but it wasn't quite the same pattern of squares. We paused the film and tried to advance frame by frame, and did see the artifact, but it flashed up and disappeared without us advancing to the next frame.
By recording about 2 minutes worth of the same 10s of the film, we were able to capture an instance of this artifact appearing:
The setup is a Doremi Showvault with IMB and a Barco 4K 23B. We had occasional quick glitches on screen with another IMB in another hall which replacing the IMB seemed to correct. The question is, because this happens in the same spot when it happens, is this the DCP or the Doremi system or both? We tried the same DCP on an IMS 3000 in another hall trying to get the glitch to show up and it never did.
Also as a side note and this is probably for another thread, but we were provided with a 5.1 and 2.0 DCP of Raging Bull. After much research and testing we confirmed it is a 2.0 surround from the original LT RT 35mm source. So, don't play it as normal. I told Park Circus they should probably let people know that, but they didn't reply. The 5.1 seems to be a matrix decoded mix put in a discrete package since there is bleed in the surrounds.
