Small theater with only 4 screens. Three of our projectors (Christie 2210 with GDC SR-1000 server), periodically get horizontal red lines on the screen during playback. We resolve it by shutting down the projector, re-seating the LEQD board, and restarting. Occasionally we have to do this twice before it resolves. Our technician has said that it may be caused by climate changes, but our booth is cool and we haven't had any drastic weather changes when this happens. Could anyone tell me what might be happening?
Help!!! Horizontal Red Lines on screen
you will experience more contact problems due to the inherent high humidity in FL , Do as Steve says as well as Leo, pull each board, wipe contacts, spray some de-oxit on connector and reseat them, in your area this should be done at least every 6 months or so. We don't have as many problems out here in the dry west!
Originally posted by John EickhofWe don't have as many problems out here in the dry west!
The only L-series projector I currently look after is in Vegas, where, needless to say, humidity is not an issue! In fact, the quart jugs I set in the pedestal for the condensation hoses coming out of the air dryers are always bone dry - not a drip in them - when I'm there for PM visits.
When installing a brand new projector, I will clean the contacts of all the cards in the cage with an alcohol prep pad, then apply a coat of G100 to both sides of the contacts, leave it to cure for 30-60 minutes, then reseat the cards. For pre-existing projectors that I service, I will apply a coat of D5, leave it for 10-20 minutes, then the alcohol prep pad to wipe everything off, then G100, wait 30-60 minutes, then reseat.
I suspect that their card cages get significantly hotter, especially ones in close proximity to a xenon arc lamp and its power supply module.
Edit / afterthought: my wife's laptop (a Dell bought in 2017, but as it has a TPM 2.0 on it, it runs W11 without any problem, and so we have no plans to replace it) started throwing BSODs a couple of years ago. Gave it a strip down, clean (in particular, the CPU fan was caked in dust, cat hair, etc.), and reassemble, treating the RAM boards with DeOxit in the process, just like I would a Series 2 projector card. No trouble since. Whether it was carefully cleaning the fan and grilles or the DeOxit that did the trick I don't know, but I guess it could have been heat cycling and/or oxidization compromising the RAM board connections.Last edited by Leo Enticknap; 08-15-2023, 08:21 PM.
CPUs and GPUs run at stupid temperatures sometimes!But yes, I see a home environment more stable than a projection room.
Re-seating/cleaning does work for computers indeed. But just imagine if our computers required re-seating as cinema projectors do. There are millions of computers, there'd be queues of people outside of computer shops. In fact, there would be "ReseatYourCard.com" businesses
I would speculate that a lot of PC and laptop owners simply trash these machines when they present a fault that could have been fixed by reseating the RAM boards and/or PCI cards. Unless there was a defect in assembly at the factory, such a fault is unlikely to appear before the computer is 4-5 years old, which many believe to be the useful life of a PC (and which with zero maintenance likely is).
- Likes 1
