I have come into possession of a Dolby Cat. 745 card, that I assumed was dead and the battery drained. However, upon checking it the voltage measures 2.83v - which to me, optimistically sounds like it could still have some life in it, and the key not be wiped. But looking at the datasheet of the CR2477N battery, it also looks like it's on the edge of the drop of the curve, where it will soon exponentially lose voltage over time. My Cat 745 has the two battery holders, so not the newer soldered on single battery.
I don't know the full history of the card, so it's more than possible that the key has been lost and someone has put a working batter in in the hope it may work, or that the card has failed in some other way (I read they often had issues?). I don't have access to a working series 2 projector to put it in and try right at this moment, but I thought that for the cost of a battery, it's worth replacing in the hope that it hasn't wiped, and that maybe it can be used in the future. However I have also read that the Dolby considered the Cat. 745 battery to be non field-replaceable, and that when attempted, the replacement procedure was fraught with issues, and often not successful. So I am keen to try and work out what the best method is for a chance of success.
My current plan is to:
- Solder wires on to the vacant battery holder
- Connect these to a bench PSU, suppling 3v
- Replace the battery, knowing that the soldered on wires are providing 3v with a good connection
